Discussion topic: WiFi test says all ok but nothing connected
This message was authored by: Miles1471
Can't seem to connect to the hub have rebooted and tested and no found issues???
Re: WiFi test says all ok but nothing connected
@Miles1471 the connection test does not pick up lost connections for a period. If the hub lights show it is disconnected (see https://www.sky.com/help/articles/hub-lights-explained-start) and the checkercdiesnt tell you Sky are aware of an issue call Sky to report the fault.
