16 Aug 2022 02:36 PM
hi, we cant find the wi-fi password, how can you find out what it is?
16 Aug 2022 02:41 PM
The wifi password should be 12 alphanumeric case sensitive characters on the back of the hub
16 Aug 2022 02:49 PM
@cookiemonsteruk thank you, but my client says they cant find this, is there a way i can find it or do i need to contact sky?
Or if it's been changed from that, a Hub reset should resore it to the one on the label.
Unfortunately if the label isn't there then only replacement hardware is viable: Sky won't have a record.
16 Aug 2022 02:52 PM
Might be a replacement hub is required if it is not on the hub.
16 Aug 2022 02:56 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you know the admin login to the hub you can view the key in the settings
16 Aug 2022 03:45 PM
Although on a Broadband Hub the default password to the admin login IS the key ; )
