Discussion topic: WiFi not working but checker says it is
This message was authored by: Gemoot11
My WiFi is not working on my mobile device or laptop. I have used the sky checker and it says all are working well but they obviously aren't. I cannot connect at all and am trying to work.
Re: WiFi not working but checker says it is
@Gemoot11
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
