Discussion topic: WiFi not working and router has a red light
This message was authored by: Matt291
My router has a red light and our WiFi is not working. When I do diagnostic checks it says everything is fine but nothing is working???
Re: WiFi not working and router has a red light
@Matt291
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
