Discussion topic: WiFi not reaching bedroom
This message was authored by: DannoAddo
Hi , I'm struggling to get any signal at all in my son's bedroom . I have tried and tested all the tips from the sky broadband help screens and nothings changed , the signal is zero or at very minimal . Could anyone give any advice please? Regards
Re: WiFi not reaching bedroom
@DannoAddo  Do you have broadband boost or did you get Sky broadband Max for your subscription with Sky?
Avatar for DannoAddo
Yeah I have broadband boost 👍🏼
@DannoAddo  If you have broadband boost then give Sky a call and request a booster, they will go through a few things with you and should then put in a request for one to be sent out for you at no cost to you.
Brilliant, thanks for your help 👍🏼👍🏼👍🏼
