Discussion topic: WiFi not good upstairs and dining room
Message posted on 06 Jun 2025 04:16 PM
I had broadband fitted today and WiFi not good at all upstairs as we can't watch Netflix upstairs also WiFi lagging in dining room
Message posted on 06 Jun 2025 04:23 PM
Re: WiFi not good upstairs and dining room
@Michelle222 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
