Discussion topic: WiFi keeps dropping
This message was authored by Isjdnxjxi This message was authored by: Isjdnxjxi
WiFi keeps dropping
Hi, I don't know if it's because of the heat, but my WiFi keeps dropping and the middle amber light keeps coming up, I have to unplug the power and plug it back in when the router cools down. Will work for 30 mins and then drop again. I have sky glass so can't use that either. Anybody know if it's a simple fix or do I need a new router?
Re: WiFi keeps dropping
Hi @Isjdnxjxi
Is it still doing it now? This shouldnt happen unless you have the router placed in a location where it would be in direct sunlight.
I am NOT a Sky Employee
