Discussion topic: WiFi keeps dropping out but says it’s ok
This message was authored by: Lisa222222
My WiFi keeps dropping out which is so frustrating, when doing tests it's saying nothing is wrong, I've reset it all several times, been on and off all afternoon
Re: WiFi keeps dropping out but says it’s ok
@Lisa222222
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
