Discussion topic: WiFi keeps dropping in and out showing orange light
This message was authored by: Jvs22
This message was authored by: Chipp1a
Re: WiFi keeps dropping in and out showing orange light
Same here even though the tests on sky show no problems
@Jvs22  What is showing orange light on the router?
@Chipp1a  Do any of the lights on your router change colour, which are the ones doing this?
This message was authored by: katiegould
wifi show orange
@katiegould check the lights on your hub again as the wifi light can either be green or out it cannot show amber. The internet light can show green or amber/orange which indicates a loss of connection to the exchange. You posted after midnight and the most common cause of the line going down is Openreach having to maintain their kit. If so it will be back by now.
