Discussion topic: WiFi keeps dropping. Need internet for work. Missing an important meeting.
Message posted on 14 May 2024 01:54 PM
Message posted on 14 May 2024 02:01 PM
Re: WiFi keeps dropping. Need internet for work. Missing an important meeting.
How long does it drop out for?
A quick drop every few weeks would not be considered a fault, infact its almost guaranteed to happen with WiFi. If you need a critically stable connection you should be using ethernet.
Message posted on 14 May 2024 02:15 PM
My husband uses two systems. One of which uses the ethernet and the other WiFi, it's only been off for 15 mins ISH.. but this may only last a few hours and drops again.
Thanks for your help
Message posted on 14 May 2024 02:28 PM
Hi @KylieS18 Please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
Message posted on 14 May 2024 03:38 PM
Yes my friend Internet been popping off every 2 days for 3 weeks 4 times a day, probably 15 min most very frustrating just upgraded so hope fully it won't do it then.
