Discussion topic: WiFi keeps dropping I want it fixed or I’m leaving sky I and fed up paying for something that doesn’
This message was authored by: Margaret19291
My WiFi keeps dropping if it doesn't get fixed I'm and leaving sky I am fed up paying for sky and it never works properly
Re: WiFi keeps dropping I want it fixed or I’m leaving sky I and fed up paying for something that do
@Margaret19291
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
@Margaret19291
You are making threats to leave to fellow customers here so it's a bit pointless.
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
This message was authored by: peter-marlow+1966
Try calling  sky  and asking  for  a  wifi booster?  That usually works
P c marlow
