Discussion topic: WiFi keeps disconnecting every hour has done since we had problem with sky q
This message was authored by Julie+te This message was authored by: Julie+te
Our WiFi keeps disconnecting every hour  we use it for work and is causing a lot of stress the problem started when sky w wouldn't work your engineer fixed the tv problem but WiFi problem has continued. I've followed steps on the app and it says there is a problem I think we need an engineer
Re: WiFi keeps disconnecting every hour has done since we had problem with sky q
@Julie+te Could you please post your router stats following the link below.
