Discussion topic: WiFi keeps disconnecting and reconnecting while in work, downstream and upstream are 0.
This message was authored by jgp1960 This message was authored by: jgp1960
Moderator note: Removed personal/identifiable details
Re: WiFi keeps disconnecting and reconnecting while in work, downstream and upstream are 0.
@jgp1960
Could you post your hub stats
As far as the image shows that it is connected but zero speed.  This is indicative of a full fibre connection where the ont modem doesn't pass the speed to the router
