Discussion topic: WiFi isn’t working internet sign not lit up
This message was authored by: Komal99
My internet sign isn't lit up on the router
Re: WiFi isn’t working internet sign not lit up
@Komal99
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
