Discussion topic: WiFi is not available in all rooms in my house.
This message was authored by: Ian+Bateman
WiFi drops out in various rooms in my house how do I fix this?
Re: WiFi is not available in all rooms in my house.
@Ian+Bateman Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
