Discussion topic: WiFi extremely slow and drops out frequently
Message posted on 17 Sep 2025 08:47 PM
My WiFi struggles to get above 40mbps and is dropping out every few minutes. My hub is literally next to me when this happens.
Message posted on 17 Sep 2025 08:56 PM
Re: WiFi extremely slow and drops out frequently
@Ah555 Do you see anything happening on the hub light or lights at this time?
Message posted on 17 Sep 2025 09:12 PM
Two lights solid one light flashing as I believe it should be.
Message posted on 17 Sep 2025 09:14 PM
@Ah555 The link shows all the hubs, NO flashing allowed!
Message posted on 17 Sep 2025 09:20 PM
Apologies again it's a solid white light
Message posted on 17 Sep 2025 09:26 PM
@Ah555 Run the diagnostic link that is copied below, if it finds something follow the links, if not then give sky a call!
Try running the line test here to see if any faults are found:
Message posted on 17 Sep 2025 09:30 PM
Done that already. Thanks I'll give them a call. Should have 500 mb so 40 and consistent drop outs is frustrating
@Ah555 From your descriptions posted, you would appear to have a FF with Sky Max hub, and as you have a speed/wi-fi issue then suggest you look at the link below and see if dropping back to wpa2-psk mode off security is better.
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
Message posted on 17 Sep 2025 09:32 PM
@Ah555 The service checker shows daily what you have with recorded 30 day's history.
