Discussion topic: WiFi drops out at least once a day
This message was authored by CAllen313 This message was authored by: CAllen313
My WiFi drops out at least once a day and only returns after I unplug and reset my router.
Please investigate as I'm not going to reset my router every 24hrs
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: WiFi drops out at least once a day
@CAllen313
No one here will investigate as we're customers like yourself.
If the service checker is still not telling you that Sky are aware you may need to call them to report it (dial 150 free from your Sky landline).
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
