Discussion topic: WiFi dropping signal and loosing connection to boosters
This message was authored by: Janie15
Message posted on 29 Dec 2024 08:51 PM
The WiFi keeps dropping the signal and loosing to connection to the boosters
Find out more
Message posted on 30 Dec 2024 06:50 AM
Re: WiFi dropping signal and loosing connection to boosters
@Janie15 sounds like the boosters are too far from the hub. Boosters should be installed no more than half way between the hub and where you need the boost as they need a goid signal from the hub to boost.
