Discussion topic: WiFi dropping every 10 minutes
Message posted on 08 Aug 2024 09:05 PM
Re: WiFi dropping every 10 minutes
I have the same problem and i'm in Devon. It says everything is good when i test my WiFi and broadband connection. Time to cancel sky i reckon, its been going on for 3 days.
Message posted on 08 Aug 2024 11:03 PM
Hi,
When the engineer checked last time, I suspected it was a fault in the cable or cable joints outside. But the engineer insisted on replacing the equipment in the house. So that worked until now.
I still suspect the issue is external in one of the cable joints outside my home must have some moisture issues.
How do I book an engineer visit - what's the best number to call?
Message posted on 09 Aug 2024 07:25 AM
@miss_jjb If you are in the UK the number to dial is 150 on your landline, listen to the voice prompts and ignore it when it tries to send a text to come back here. The lines normally open at 8am.
Message posted on 19 Jul 2025 04:45 PM
Yep ours is doing the same
