Discussion topic: WiFi down but your tests say it’s fine
This message was authored by: JB153
WiFi has gone down but your service checker and tests all say it's fine?
Re: WiFi down but your tests say it’s fine
@JB153
This is a customer ➡️ customer discussion forum where we try to help other Sky customers. You aren’t speaking to Sky staff by posting on here.
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
@JB153 If the lights on the hub say's it's down then use those rather than a software test getting it right.
