Discussion topic: WiFi down. However everything green on Reuter. What do I do?
This message was authored by: 13londonlads
Message posted on 08 Jun 2025 05:50 PM
WiFi down but all green on Sky Reuter. Tried everything but nothing seems to work.
any tips!
Message posted on 08 Jun 2025 06:06 PM
Re: WiFi down. However everything green on Reuter. What do I do?
@13londonlads Do you see the device name when connected, if a mobile try a disconnect from the wireless wi-fi and then see if you can re-connect the same device?
Find out more
Message posted on 09 Jun 2025 07:27 AM
@13londonlads try powering down the hub for an hour which should clear a fault where the hub is connected but no data flows caused by an issue with the server at Sky's end.
