Discussion topic: WiFi doesn’t seem to be working
Message posted on 01 Apr 2024 10:00 PM
I've tested the broadband with the WiFi checker on my phone using my data, and it appears to be working ok. Then I connect to the WiFi and it's not working. The router and WiFi system has been reset and still nothing
Message posted on 02 Apr 2024 08:07 AM
Re: WiFi doesn’t seem to be working
@AndySch there are a number of dimilar reports if the Connection test is not reporting a known fault you need to report the fault to Sky. To help I am escalating your post to the Sky team who support the forum who should be in touch soon to offer you a private chat session to get this sorted. Keep an eye onnthe forum as if you miss the message just click the chat icon which will be added to the forum pages for you to use.saving a long phone call.
Given its been a holiday weekend and thst there are loads of faults reported it maybe a few days before Openreach have capacity to check your line.
Message posted on 02 Apr 2024 10:24 AM
Hi @AndySch
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Message posted on 04 Apr 2024 10:26 AM
We are still looking to help you @AndySch . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Message posted on 08 Jan 2025 02:48 AM
hey, we have the same problem, did it get fixed?
Message posted on 08 Jan 2025 02:50 AM
@Alexa000
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
Message posted on 08 Jan 2025 03:03 AM
It says it's all good but on the box the lights are red not green no matter what we do
