Discussion topic: WiFi disconnecting frequently
Message posted on 25 Oct 2024 09:52 AM
Wifi service keeps disconnecting very frequently. Tried switching off and on the router but no luck. It comes back without any intervention. But the disconnection is so frequent that even a min video keeps buffering every 10 sec to load.
Message posted on 25 Oct 2024 10:01 AM
Re: WiFi disconnecting frequently
I have the same issue and trying to work
Message posted on 25 Oct 2024 01:51 PM
Message posted on 25 Oct 2024 03:41 PM
Black router
Message posted on 25 Oct 2024 04:14 PM
@Amritha Could you please post your router stats following the link below.
Message posted on 25 Oct 2024 04:39 PM
@Highlinder Am not able to login with both the credential options. Am sure am entering the correct WiFi password. It just keeps prompting to enter the credentials again. Could this also be part of the issue? Or am missing something..?
Message posted on 25 Oct 2024 05:27 PM
@Amritha What browser are you using to login on the router?
Message posted on 25 Oct 2024 06:43 PM
@Highlinder @Chrome. Have tried both from mobile and laptop. But it's the same
Message posted on 25 Oct 2024 08:26 PM
@AmrithaSo you use admin as the username and your password using the Wi-Fi password on the router unless you have changed the system password on the router.
Message posted on 26 Oct 2024 10:10 AM
@Highlinder I do not seem to have permission to upload images. Any link where I can upload the stats?
Message posted on 26 Oct 2024 10:15 AM
My Internet not working since yesterday. I try so many time restart but still not working
Message posted on 26 Oct 2024 02:18 PM
@Amritha Are you clicking on the camera icon below the text box to upload your picture?
@Dani181 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
