This discussion topic has been answered Discussion topic: WiFi cut out at 12:15
Message posted on 11 Nov 2025 12:48 AM
My WiFi has cut out at 12:15 in FK10 area not sure if it's area related as website says everything should be all good. Been through all the suggested steps and reboots and still got a red light on the modem.
Message posted on 11 Nov 2025 05:23 AM
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's not, use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
