16 Apr 2023 10:26 AM
SSID connection - fail notification to contact SKY
Since the SKY broadband was installed I have to reboot once a week, to get connection.
Two weeks ago my neighbour had a new SKY install and the problem has got worse.
16 Apr 2023 03:33 PM
Wireless interference is usually terrible with Sky wireless routers when more than 1 is present near your location because Sky routers only work with 2.4Ghz & channel 36 on 5Ghz. The solution is to move the wireless router to a better location. And if that doesn't work invest in a better third-party wireless router that works with Sky DHCP Option 61 authentication.
