Discussion topic: WiFi been out all afternoon
Message posted on 30 Sep 2025 06:25 PM
Our WiFi has been out all afternoon and is still not working now 18:24
Message posted on 30 Sep 2025 06:44 PM
Re: WiFi been out all afternoon
@Chuggers
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Message posted on 30 Sep 2025 06:46 PM
Same here. Did you fix it?
Message posted on 30 Sep 2025 07:28 PM
Ours is exactly the same
Message posted on 30 Sep 2025 07:53 PM - last edited: 30 Sep 2025 07:58 PM
Sky supplies broadband to over five million households: that scale of operation means at any particular point in time thousands of the individual Openreach circuits to Sky subscription addresses will be faulty, irrespective of any wider area outages.
