Discussion topic: WiFi at top of garden?
Message posted on 21 May 2025 08:00 AM
Hi we have a sky router in living room pick in living room and one puck in one bedroom. Wanting to use WiFi at top of garden which is approximately 20 metres from hub. We are not on full fibre so our speeds aren't brilliant but everything works great. We have a power point at top and bottom of garden can I get a booster that plugs in so a laptop can be used or is it not that simple?
thank you
Message posted on 21 May 2025 09:28 AM
Re: WiFi at top of garden?
@Kirsty1518 Are they both just external power points that you have? Not that simple to do using that method as in general the powerline that would possibly work for you is not Externally rated for outside working. If you were doing it on a temp basis that would work ok. Speed will not be up there so it is a try and see. Take a look at the link below to give you the idea.
TL-WPA4220 KIT | AV600 Powerline Wi-Fi Kit | TP-Link United Kingdom
