Discussion topic: WiFi and phone
Message posted on 02 Oct 2025 12:36 PM
WiFi and phone
My WiFi is on and off affecting lots of devices phone is worse than ever
Alexa is going off all the time
computer keeps flashing no internet
Message posted on 02 Oct 2025 12:49 PM
Re: WiFi and phone
@BB211
If you are having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
