Discussion topic: WiFi and Ethernet not working upstairs
Message posted on 06 Jun 2025 08:06 PM
I've had Sky full fibre installed and downstairs near the router I get 600+mbps.
As soon as I go upstairs I get less than 30mbps on WiFi
I've got 2 to-link AV600 set up that I had in my previous house that worked fine, I've set it up here and I'm still only getting 30mbps via Ethernet on the tplink with my PC.
any ideas on how to fix? Hub is in the front room of the house closest to the stairs and the wifi drops below 30mbps at the top of the stairs, never mind the Ethernet situation
Message posted on 06 Jun 2025 08:23 PM
Re: WiFi and Ethernet not working upstairs
Powerline networking performance can have huge variations between properties, because, unlike ethernet cable, mains cabling topology is incredibly disparate.
Message posted on 06 Jun 2025 08:29 PM
@Bethancaitlin The only full speed way is to run an Ethernet cable from point A to Point B.
Message posted on 06 Jun 2025 08:49 PM
I get that however I used the TP-Link in my previous house and achieved the same speed as next to the router. I run a gaming PC and I'm not naive to networks and wiring.
Also doesn't explain how my WiFi can drop from 600+ mbps to 30 just by going from the bottom to the top of the stairs.
I get that can be the case but it Also doesn't explain how my WiFi can drop from 600+ mbps to 30 just by going from the bottom to the top of the stairs.
Message posted on 06 Jun 2025 08:53 PM
@Bethancaitlin The sky information on speed, what sky hub did you have fitted, and the location because you got fibre is all wrong, central hub and central speed.
https://www.sky.com/help/articles/broadband-speeds-explained
And for speed related issues good read.
