Discussion topic: WiFi ain’t working
This message was authored by: Amy232
WiFi ain’t working
I'm away and I really need WiFi on please and I need to check my cat if she's ok on cctv thank you
Re: WiFi ain’t working
@Amy232
This is a customer led discussion forum where Sky customers are available to help other customers. You aren’t contacting Sky Customer Services by posting here.
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
@Amy232
Also note that not being present at the address makes the basic troubleshooting and diagnostics which Sky will insist on going through extremely problematic.
Avatar for Amy232
Level 0 icon
Thanks. I think hub is not connected
@Amy232
Which kind of illustrates my point, really.  You could try triggering the 'Check my connection' option remotely: that might result in a fault investigation from Monday onwards.
