This discussion topic has been answered Discussion topic: WiFi Max: Settings have disappeared from the My Sky App - 6/6/24
Message posted on 10 Dec 2025 07:13 AM
Re: WiFi Max: Settings have disappeared from the My Sky App - 6/6/24
@Babesta have you bought the WiFi Max package from Sky? If you have then the parental control options should be in the My Sky app. If you haven't they wont.
Message posted on 10 Dec 2025 04:51 PM
Message posted on 10 Dec 2025 04:57 PM
Message posted on 10 Dec 2025 04:59 PM
Oh right i didn't realise that about the photos. Yes I understood and the photos show that I have WiFi max and the settings aren't there
Message posted on 10 Dec 2025 05:44 PM - last edited: 10 Dec 2025 05:56 PM
@Babesta You are going to have to ask the question of sky on this one, yes you have sky Max but no idea if they work with the Sky Gigafast+ 5Gb/s and that wifi7 sky Hub that you have, may be possible if someone else using the same combo can confirm for you!
Does seem that all can be done, take a look at the video, that may give you a better idea, seems you have to tap on a device then go from that point!
Parental controls with Sky WiFi Max | Sky Help | Sky.com | Sky Help | Sky.com
