19
This discussion topic has been answered Discussion topic: WiFi Max: Settings have disappeared from the My Sky App - 6/6/24
This message was authored by: Stacey441
Wifi parental control settings has vanished off my app this morning - any ideas how to get it back please?
Moderator note: subject of thread updated to better reflect the conversation
Re: WiFi Max: Settings have disappeared from the My Sky App - 6/6/24
@KevNewMedia all back working properly.
Re: Wifi parental controls missing on app
@Stacey441 try loging out and closing the app then try again if the controls dont come back hive Sky a call.
This message was authored by: AnnaWS
Connected device list vanished from app
I can't unpause devices my children use this morning because the connected device lists and groups I'd made have completely vanished from the broadband section of the app. Is there another way to do this? Why has it vanished? Thanks
Re: Connected device list vanished from app
@AnnaWS looks like Sky have an issue as other people are reporting similar issues and my own app is misbehaving. I have posted in a closed forum alerting our Sky contacts hopefully they will sort the problem quickly.
Avatar for Stacey441
Thank you, I did try that but it didn't work. I will have to call sky later if I get a chance.
@Stacey441 since posting I have seen other posts reporting the same and my own app is not showing any WifiMax settings so it looks like Sky have a problem. I have alreted the forum manager so he can find out what is wrong.
This message was authored by: aaarrgghhh
Came here looking for answers to this exact issue, glad I'm not alone!
This message was authored by: KevNewMedia
Posted by a Sky employee
Hi Everyone
Thank you for bringing this to our attention and thanks for tagging me @Chrisee
Our support teams advise this issue should now be resolved. Can I ask you to try and log out of the app and back in, and let me know how you get on?
Kev
Community Manager
Grand, thanks for confirming @Chrisee
Kev
Community Manager
This message was authored by: Babesta
Hi I'm having this same issue and every time I speak to Sky about it, they just keep talking about the broadband shield and not the actual parental controls through WiFi max, any advice on how I can fix it? Thank you
@Babesta You have posted multiple times, you need to call sky, the parental controls on the sky Max is all tied to your sky account, so they need to look and work with you for any fix!
I have tried this and all they talk to me about is the broadband shield or tell me how to set parental controls on my kid's phones and consoles, not on the sky app
I appreciate you sending me this, however I have followed all of this multiple times
