This discussion topic has been answered Discussion topic: WiFi Hub Max not appearing in product settings
Message posted on 31 Aug 2024 02:29 PM
I've just upgraded and recieved the WiFi Hub Max, however, it doesn't appear in my product settings tab on the Sky App, so I'm not able to change my WiFi password. Is there a fix to this?
Message posted on 31 Aug 2024 02:43 PM
@CharlieJ1905 How long ago did you connect the Max router? As it can take 24 hours to appear in the product seeings on the Sky app.
Message posted on 31 Aug 2024 08:43 PM
Re: WiFi Hub Max not appearing in product settings
Did you download the sky max hub app to set it up ?
Message posted on 31 Aug 2024 08:45 PM
@peter-marlow+1966 There is no separate app that you download for the new broadband max hub it is integrated into the Sky app that everyone uses.
Message posted on 31 Aug 2024 08:54 PM
Scran the q r code that come with it. I have had it since January when I had full fibre to the property installed, the q r code tells you to redownload the my sky app, I did and it shows then and you can set it up, also setup times for devices to go off from the Internet if you have children, tells you what is connected and what is not purse devices, and remover disconnected ones if you want, all on the my sky app after you have scraped the q r code and reinstall the my sky app
Message posted on 31 Aug 2024 09:00 PM
Message posted on 31 Aug 2024 09:13 PM
Message posted on 31 Aug 2024 09:23 PM
Hope this helps you
Message posted on 31 Aug 2024 09:42 PM
@peter-marlow+1966 That is just the normal my Sky app. There is nothing special about it. Everyone has it for other services.
Message posted on 31 Aug 2024 09:46 PM
The first 2 photos are off the sky website, the third one is off my, my sky app after I scanned the Q r that come with the max hub and reinstall the my sky app foe the latest version of it
Message posted on 31 Aug 2024 09:49 PM
@peter-marlow+1966 Yeah, always for getting the beta version of the app. So nothing new.
Message posted on 31 Aug 2024 10:02 PM
You know what just forget it try and help even with evidence from sky themselves and you get shot down even when you know what you are talking about
