Discussion topic: WiFi Dongle that works well with the Sky Max hub?
This message was authored by: azza19892
As title, any recommendations for Wifi dongles?
Just i know, the Sky Max WiFi is unreliable and i don't want something that keeps dropping connection.
My current one (tp link archer t3u) drops constantly with Sky but was fine with my old provider.
Thanks for any info
Re: WiFi Dongle that works well with the Sky Max hub?
@azza19892 Drop the sky Max hub back to wpa2-psk to suit the Tp link module, use the app to adjust the hub!
Avatar for azza19892
Level 2 icon
Thanks, i'll give this a try
Also, not sure why i only get this speed
@azza19892 See the box that say's details and also the wireless properties, then that is where you need to look! Details will be supplied and what you have / what you are syncing at / what the device is capable off.
Edit:- as @TimmyBGood has pointed out, but if you wish to and throw it all at the wall, then the daddy off them all is the Archer TXE70UH.
As to getting what you think you need then different story!
@azza19892
140Mbs over 802.11ac into an aerial the size of a fingernail isn't exactly underperforming.
