5
This discussion topic has been answered Discussion topic: Wi-fi working but devices not able to access internet
This message was authored by: MikeB01
My Sky WiFi hub and the Sky.com test shows everything is connected and operational, however a number of devices are unable to access internet services.  I have restarted the hub which has, if anything, made things worse!
What else can I do or is this a wider issue?
This message was authored by: dandy4 Answer
Re: Wi-fi working but devices not able to access internet
Further to my last post, resetting the router seems to fix the issue.
Avatar for MikeB01
Further update - SkYQ mini-box reconnect attempts shows the the router is not issuing IP addresses to devices.
This message was authored by: Dobdobdobby
I am also having the same problem, I've currently worked around it by bridging the connection to an alternative WiFi access points that are not SKY
Avatar for MikeB01
Thanks - have narrowed my issue down to the extension router. Am going to try resetting this to see if it works
Avatar for MikeB01
Tried the reset on the main router. Sky Q box now not recognised by the network...and this has an Ethernet connection!!
