Discussion topic: Wi fi failing no wi fi despite test saying no issue
This message was authored by: Angela+nhs
My wi fi failing on broadband
Re: Wi fi failing no wi fi despite test saying no issue
@Angela+nhs
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
@Angela+nhs
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
