Discussion topic: Wi-Fi turned off and flashing red
This message was authored by: Jadeegrimleyy
Wi-Fi turned itself off for no reason and was flashing red (on the internet light)
Re: Wi-Fi turned off and flashing red
@Jadeegrimleyy a flashing internet light means the hub is trying to connect. Check thst the czbles are properly connected and try a reboot by disconnecting the power for a few seconds. If afterthat the unit still doesn't connect using a mobile connection go into the service checker in the MySky app which msy or msy nit have picked up the issue but will tell you if Sky are aware of a fault affecting your line. If they aren't give them a call to report it so it can be fixed.
Avatar for Jadeegrimleyy
I know this, but why would it be doing it? There is no issues with cables or placement of box
