7
Discussion topic: Wi-Fi slow
This message was authored by Roy1982 This message was authored by: Roy1982
Wi-Fi slow
Since upgrading my TV package to UHD my Wi-Fi is terrible. It's fine for the use of the TV bit if I try to use my phone at home I have to turn my phone to 4g or nothing will load. For example I've just had to turn it off now to fill this form out!
Roy1982
This message was authored by Roy1982 This message was authored by: Roy1982 Answer
Re: Wi-Fi slow
Summary Status
We configure your Sky Hub with all the settings to enable it to work straight away. Advanced users will find links below to common settings you may wish to change.
For more settings select the menu options at the top of this page.
Status of your broadband and WiFi network
Broadband Connected
WiFi Enabled
WiFi Network Name (SSID) SKYZHXSS
WiFi Network Visible Yes
Current WiFi Channel 11 (2.4 GHz), 36 (5 GHz)
WiFi Encryption WPA2-PSK
VoiceConnected
Devices connected to your home network
Device Name MAC Address UNKNOWN 0a:fd:ba:09:ef:ee UNKNOWN 32:95:01:1f:fe:ea UNKNOWN 46:13:c6:ab:44:1d XBOXONE c0:33:5e:39:7b:b0 SKY+HD b0:3e:51:c3:e4:42 SKY+HD d4:da:cd:0b:77:71 XboxOne 4c:0b:be:71:06:1a UNKNOWN 1c:fe:2b:fe:0d:34
Re: Wi-Fi slow
@Roy1982 Could you please post your router stats following the link below.
Roy1982
Re: Wi-Fi slow
Summary Status
Broadband Connected
WiFi Enabled
VoiceConnected
Re: Wi-Fi slow
@Roy1982  That is not what we are looking for. You have to follow all of the steps to the end. You should see something similar to what is shown at the top of the link posted.
Roy1982
Re: Wi-Fi slow
It won't let me log in, just keeps coming up with the same thing, "your password will be sent encrypted" then nothing happens.
Re: Wi-Fi slow
@Roy1982
Its ok to procede. You are logging on from inside your own network
Roy1982
Re: Wi-Fi slow
It will not let me past this point.
Roy1982
Re: Wi-Fi slow
Manged to get on in the end. @Highlinder  @cookiemonsteruk does this anything to you guys?
