Discussion topic: Wi-Fi issue with devices connecting to sky wi-fi extenders i.e. Sky TV Box
This message was authored by: GaryB449
Recently moved from BT to Sky and in theory using the same fibre infrastrucutre. However, Sky seems to be using their sky tv box as an extender and I am finding that devices that connect to the extender, rather than the Hub have intermittent and slow wi-fi and the apps on Sky TV keep glitching. Anyone else having this issue? Is it possible to dictate where the devices connect to? Any help appreciated.
Re: Wi-Fi issue with devices connecting to sky wi-fi extenders i.e. Sky TV Box
Hi @GaryB449
This can happen yes, there is no way to select which devices connect to each Sky node but you can disable the hotspot feature in the Sky Q box settings.
I am NOT a Sky Employee
