Discussion topic: Wi-Fi in my house
Message posted on ‎31 Mar 2025 07:03 AM
Wi-Fi in my house
I have been upgraded to sky fibre about four weeks ago my telly buffers quite often there is no Wi-Fi in my main bedroom. One sky booster hub does not connect to Wi-Fi because it is too far away. My previous sky was a lot better. Very disappointing.
Message posted on ‎31 Mar 2025 07:51 AM
Re: Wi-Fi in my house
@Mark529 ol;d Sky boosters donot work with the newer hubs. You need a matched unit.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 matchedextenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
