29 Oct 2023 10:01 PM
My Wi-Fi keeps dropping right off in the bedroom where my mini box is which is hard wired to Ethernet ?? The sky mini is set for wired as well ??
30 Oct 2023 07:01 AM
Posted by a Superuser, not a Sky employee. Find out more@SueGav have you turned off the WiFi on the Q mini? If you have turn it back on as it will then act as a wfi hot spot for the Sky network but still use the ethernet cable for its backhaul to the hub assuming that is where the ethernet cable connects to.
31 Oct 2023 12:40 PM
Hi Thanks ,, Does that apply for all the mini boxes then?
31 Oct 2023 02:31 PM
Posted by a Superuser, not a Sky employee. Find out moreYou dont need WiFi switched on for all mini boxes but if you want WiFi coverage in an area then you'd need to switch the WiFi on for the mini box yes. You can still leave the ethernet cable connected as it'll still use that connection for the backhaul.
