Discussion topic: Wi-Fi down. Reset twice and still not working
Message posted on 18 Jun 2024 10:23 PM
Hi,
having WiFi issues. I have sky glass which means all my functions are now gone. I've tried resetting it twice with no luck. When doing the WiFi test it comes back as fine, all lights are green but still no connection on any device.
Message posted on 19 Jun 2024 06:44 AM
Re: Wi-Fi down. Reset twice and still not working
@Eileen7 try powering down the hub for at least 30 minutes as that should clear a fault where the hub is showing green internet lights but no data flows. This fault is in the Sky server your connection is using.
Message posted on 19 Jun 2024 08:12 AM
Done this and still nothing.
The voice light is now showing amber, Wi-Fi green but internet no light at all.
