Discussion topic: Why won’t my sons pc connect to the wifi
This message was authored by: Barney9
Why won't my sons pc connect to the Wi-Fi?
Re: Why won’t my sons pc connect to the wifi
@Barney9 there are many possible reasons but first using a mobile phone check there is a decent signal in the area near the PC. Next check you  are entering the correct password it is very easy to mistake a number for a letter. If you are certain  you are and a reboot of the computer doesnt help try updating the drivers.
If still stuck pleaee includecsome details including what OS is runjing and the makecand model of the wifi card.
