Discussion topic: Why o why did I get Sky Glass
This message was authored by: Rocker12
Just upgraded from Sky Q to Sky Glass and would you believe it Openreach today have **bleep** up the broadband and left me with no phone  noTV and no broadband
Why oh why did I upgrade to this and end up with nothing 😩
This message was authored by: JPR007
Re: Why o why did I get Sky Glass
@Rocker12 Unfortunately that is the risk with putting all your eggs in one basket, if the broadband goes down you lose the TV as well...one of the reasons i've decided to stick with Sky Q for a little while longer yet.
Have you reported the fault with the broadband to Sky, assuming the broadband is with Sky?
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
This message was authored by: IRegretSkyglass
Im in the same boat.. the amount of sky customers down seems to be wider than the "local area" mentioned in my text.
@IRegretSkyglass
How many do you reckon?
Well local community posts are showing outages outside of my village and up to 20mile away. If that's really the case I wouldn't say it's a local problem..
Avatar for Rocker12
Back on line now .Wow that was frustrating .Had my gripe and looking back it was not Sky's fault .
I have had Sky Glass for coming up to a month now .When I order Sky Glass everyone told  me not to and stick with Sky Q I would regret getting Sky Glass .I must say I love the Sky Glass .I was a bit concerned that you could not record on Sky Glass but now I have got use to the play list .I do not miss not being able to record. The play list is good once you get use to it.I personally would not go back to Sky Q now I much prefer Sky Glass
Has long has your broadband does not go down that is 😉
@Rocker12 I have had Glass and Stream since soon after launch and wouldn't go back either . There is a risk of broadband going down but that is quite rare in practice especially as lines are migrated to full fibe. You can link a Glass TV to a mobile hotspot assuming you have lots of data spare.
Q of course is not immune from issues especially in bad weather and given there are no plans to replace the satellites its life is limited.
This message was authored by: Jojo23
Same her had it 6 months and has been broken time than not, big regret
The UK is around 800+ miles long, each telephone exchange can often serve towns & villages within about 5-10 miles and then those smaller exchanges are often wired up to bigger ones that can cover 25+ miles especially if you are in a rural area. So yes if you and a few local villages are experiencing issues that is indeed a local problem rather than an area or national problem.
I am NOT a Sky Employee
