Discussion topic: Why is my broadband at 1.6mb down load
Message posted on 19 Jul 2024 08:41 PM
Why is my broadband at 1.6mb down load speed when it should be 600mb
Message posted on 20 Jul 2024 08:08 AM
Re: Why is my broadband at 1.6mb down load
@dean+t what speed does the My Sky conection test show? That regukarly tests download speeds and you can see the results for the last few days in the app.
Next question how are you measuring speeds? If using a site kike Speedtest.net tgen thecresult shows tge slowest part of the transfer which is often the WiFi sped in your home. To get a reliable result you need a device connected by a known fast link which for Ultradast+ would be a direct gigabit Ethernet cable.
There can rarely be issues with full fibre connections but to get them checked out you have to exclude issues like flaky WiFi first.
