Discussion topic: Why is my Sky broadband so unreliable?
Message posted on 05 Aug 2024 09:07 PM
Sky Broadband Tests indicate all is "Good" with 35MB speed to the hub, but it is far from good as internet pages are slow to load or don't load at all! Everyone at home mainly uses their 4G instead. The problem exists even when no is down loading/streaming from the internet etc...I have discussed this issue with Sky and they sent out a new router which has not helped at all. It seems ridiculous that we are paying for a service that is unreliable.
Any help would be welcome?
Message posted on 05 Aug 2024 10:06 PM
Re: Why is my Sky broadband so unreliable?
That is the speed to the router, hub the more you have connected to the Internet by wifi or ethernet cable the less the speed to each one gets, e g 5 things connected to the Internet devide that by 35mps and that's roughly what each tv, phone games console laptop and tablet will be getting , the more items you have connected the less mps each one gets,
Message posted on 05 Aug 2024 10:07 PM
You probably need at lest 100mps
Message posted on 06 Aug 2024 08:29 PM
Thanks for the reply, i understand what you are saying, however the problem still happens even when there is only one or two divices connected. When we first had Sky Q & Sky Broadband installed everything worked perfectly and nothing has changed i.e same number of devices connected now as what we had at the start when things worked well. The only thing that has changed is that the Broadband has gradually become worse over time to the point that it is sometimes useless. Thanks
Message posted on 06 Aug 2024 08:31 PM
@B1110 What colour of router from Sky have you got black or white?
Message posted on 06 Aug 2024 11:18 PM
Hi, The router is black
Message posted on 07 Aug 2024 07:06 AM
@B1110 in that case please pist your hub's connection stats as explained here Find your Sky Broadband router statistics
