Discussion topic: Why does the sky broadband 'test' tell me its working when it clearly isnt?
This message was authored by: Huntsman64
Unfortunately due to the age of the house I've moved into I can't have fibre, so I have 'superfast' plug into the phone line broadband.  It is incredibly unstable, and is currently off.  Why does the test tell me it's working when it isn't?  The box has 4 lights, power and wifi are green, Internet is off completely and voice is orange.  Noting is working!!!
Re: Why does the sky broadband 'test' tell me its working when it clearly isnt?
@Huntsman64
