Discussion topic: Why did I switch to Sky broadband
This message was authored by: itsmmeme
So like an idiot I believed the sky lies and signed up. Speeds as promised then it went to hell. Slow speeds, dropping out at regular intervals. Try to contact sky - impossible. They don't want to know. Customer and Service are two words that sky do not understand  It's a simple case of give us your money and sod off.
Re: Why did I switch to Sky broadband
@itsmmeme
Which hub do you have? White or Black?
I am NOT a Sky Employee
Avatar for itsmmeme
Black, stands upright, 4 lights across bottom, all green. This morning I was down to 14 mbps. It's currently back to 110 mbps.
This message was authored by jamesn123 This message was authored by:
This message was authored by jamesn123 This message was authored by:jamesn12
@itsmmeme
Was that speed over WiFi or ethernet? Its recommended to test over ethernet because you then know if your issue is related to WiFi performance or the line itself.
Avatar for itsmmeme
Ethernet. Stopped using wifi couple of weeks past in the hope it would solve the problems but no such luck.
Okay,  please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
Avatar for itsmmeme
Won't let me in, says 'Your connection to this site is not secure' No matter what I try I get the same message
@itsmmeme
You should be able to bypass the message & ignore it.
Make sure your using a non iOS device, or at least use a different browser such as Chrome.
Avatar for itsmmeme
Don't know if it makes a difference - I have Sky Broadband Full Fibre 100
@jamesn123
@itsmmeme
You should still be able to access your stats but either way dont worry. If you have full fibre, the chances of it being a line issue are quite slim. You could run a speedtest via ethernet to check it.
Otherwise you'd need to do some WiFi troubleshooting there is a guide here you can try; https://www.sky.com/help/articles/broadband-diagnostic-which-sky-hub
