3
This discussion topic has been answered Discussion topic: Why can't I connect my ring door bell but all my other devices connect
This message was authored by: Marcybs38
We have a ring door bell . We went away the weekend disconnected the WiFi and came back yesterday. Tried to reconnect the ring door bell and keeps saying check your WiFi connection. All our other devices are connected no problem and our sky glass tv. We have contacted ring and they have said we need to contact sky but we're getting no where
This message was authored by: Highlinder Answer
Re: Why can't I connect my ring door bell but all my other devices connect
@Marcybs38  If it connected before without any issue. Might be worthwhile trying to reset it and starting like it is new out of the box.
Avatar for Marcybs38
Level 0 icon
Thankyou ..yes we have done all that and gone through all this many times with ring on the phone. They are saying there's either a problem with my WiFi which there obviously isn't or the device has now got a fault. If so they will replace it but I just need to prove to them that there is no problem with my WiFi connection.
@Marcybs38Which router did Sky send to you for your broadband from the link below.
