Discussion topic: Which wifi packages will provide a device that connects to a Master 5c socket?
Message posted on 08 Apr 2024 12:54 PM
Hi I have just moved into a new rented house. There is a Master 5c socket, which I need wifi to connect to. The landlord does not want anything else installed. Which Sky packages can I buy which will connect to this socket without any further installation being required?
Message posted on 08 Apr 2024 01:54 PM
Re: Which wifi packages will provide a device that connects to a Master 5c socket?
@Becca901 That would be superfast broadband.
But with the infrastructure changing your landlord will be at disadvantage that not offering full fbre broadband as the copper network is slowly closed out You can check what services are available via the link below.
.https://www.sky.com/broadband
Message posted on 08 Apr 2024 03:27 PM
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Message posted on 08 Apr 2024 03:28 PM - last edited: 08 Apr 2024 03:30 PM
Note that in any area with FTTP availability it's not now possible for ISPs to offer FTTC (connecting over existing copper) because they cannot purchase such service on the wholesale market.
While your landlords concern is understandable, it's simply not going to be realistic in the long term.
